Suspension Technical Archives - Isuzu/Honda at Off-Road.com
May 12, 2008
Superchips wants to know: What is the main reason you would purchase a new tuner?
Performance gains
20%
Torque gains
10%
Fuel mileage gains
30%
Powertrain Warranty
0%
Optimize your vehicles performance
40%
View Results
Price and Compare Vehicles:
New | Used | Powersports Go button
  • Installing CALMINI's 3" Suspension Lift
    It took us a total of ten hours, start to finish, to install this lift. If you have access to plenty of friends, air tools, and a compressor, it will take you about the same amount of time.
    4x4 Shackle Lift and Polyurethane Bushings
    Most light trucks use compression-type shackles (the frame is above the shackle, which is above the spring). These instructions are the same for all vehicles that use compression-type shackles.
    Isuzu CALMINI Shackle Lift
    All Isuzu light trucks use compression-type shackles (the frame is above the shackle, which is above the spring). CALMINI Manufacturing makes an excellent extended shackle that replaces the stock shackle.
Sponsored LinksSPONSORED LINKS
Need Gas Mileage & Power?- Free flowing performance exhaust can increase gas mileage and increase power. We can all benefit from increased mileage and increased horsepower & torque improves towing, mud-slinging and the ability to turn those larger tires you put on your truck. See what Flowtech Exhaust has for your gas or diesel truck.
"Stickers, stickers, stickers!" You don't have to beg - you can get them for free! Just simply register and Off-Road.com will send you stickers from our participating companies. It's free and easy, so slap them on your ride, house or friends. Click here to register and get sticky...
ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am.  First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles.
In the Business of Off-Road? - If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
